Thread: What size sand filter do I need for my pool?
    While the pool is down for the winter, I've decided to move away from my current cartridge filter for various reasons. I think I've decided I want to use a sand filter with a little DE added to it. The problem is that I've read conflicting information on the size of sand filter that is needed. I've read that two turnovers in 8 hours is sufficient for a filter. Then I've read that about 3.0 feet of filtering area is recommended for a small IG pool.
    Here are my current pool specs:
    Astral Pools USA pump - IGP2010 1HP:
    http://www.astralpoolusa.com/index.php? ... Itemid=310
    I have a replacement pump (Pentair 3/4 HP) as a backup since I thought my old pump died about a year ago but I got it fixed before the replacement one arrived.
    http://www.pentairpool.com/pool-owner/p ... ps-165.htm
    A pool calculator says I have about 8600 gallons of water in my pool, which is pretty small for an IG pool.
    I'm looking at three sand filters due to cost/benefit ratio:
    1) Hayward 18" S180T (can purchase for about $190 shipped)
    2) hayward 21" S210T (can purchase for about $240 shipped)
    2) Hayward 24" S244T (can purchase for about $305 shipped)
    http://www.hayward-pool.com/prd/In-Grou ... 5516_I.htm
    I know bigger is better for a filter but we don't have a ton of money to spend at this time. If I have to backwash every month that is OK but I don't want to backwash every week.
    Pool Size: 8600 gallons - rectangle 12'x24'
    Pool Type: Inground with vinyl liner
    Filter: Hayward Pro-Series S244T - 300# Sand Filter
    Pump: Astral Pools IGP2010 - 1HP
    22,369
    Re: What size sand filter do I need for my pool?
    Given your situation and having a 1hp pump I'd go with the 210. If your pump was a 2-speed you could get by with the 180.
    Thanks Bama Rambler!
    The 18" is out for sure. I'm probably going to try and get the 24".
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I've got an S244T.
    No matter which of the 3 you get (and, for <9K gals, I'd go with the S180T), put unions in so that you can get the top of the filter off w/o cutting pipes. If you ever want to get into the filter, you'll be happier. With getting into the filter in mind, have you considered a a side-mount model, like the S210S?
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Dec 2011
    5
    A few simple calculations can be utilized to properly size a sand filter.
    Volume divided by desired turn over (in hours), divided by 60. (60 mins)
    Lets say for instance you want a 4 hour turnover
    Pool = 8600 Gal, divided by four, divided by sixty = 35.8 gpm This would be your target flow rate to achieve your 4 hour turn over.
    An easy way to further calculate your GPM into required square ft of filtration area is...
    15 gpm per sq ft, divided by 38.5 = 2.38 sq ft or required filter area for 4 hour turn over.
    Now if you want to turn your pool over every 6.4 minutes...give me a call...
    Thanks for the follow up replies!
    I was able to get the S244T through an Amazon open box special for $253 shipped about two weeks ago. The freight company is supposed to deliver it tomorrow morning. I'll assess what plumbing components and I'll definitely use unions.
