Thread: tcpiii in Charlotte
    Feb 2008
    Charlotte NC
    44
    tcpiii in Charlotte
    Greetings! I bought my present residence in 2002 which, somewhat to my dismay at the time, came with a pool. But my 5 boys were delighted. After most of a season pouring in a fortune of baquacil products and still rarely being able to see the bottom drain, I found poolforum.com and braved the conversion. Pool management has been relatively simple since then, and much, much cheaper. Furthermore, I now love our pool! Last summer, I lamented the demise of poolforum.com, but never came over here. Thanks for creating the new forum.
    I opened my pool on Sunday Mar 2 even though the water was still only 50 - just got tired of looking at the pool cover. Other than being cold, the water was in good shape - still 3ppm FC, 43 CYA, TA 100, low ph at 6.7 (my fill water from a well is acidic) but a couple of boxes of borax fixed that. I found a lot of small blue particles in the skimmer sock - after a few minutes of puzzlement, I figured out that they came from the bottom of the deteriorating winter cover. . . . now, after a couple of days of filtering, they're basically all gone.
    I'll post a picture once the leaves come out on the (too many!) trees surrounding the pool.
    Coty
    22,000 gal, IG vinyl, 3/4 hp pump, 300lb sand filter (switched from DE), converted from baquacil (thanks to Ben), BBB since 2004
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome!
    30,426
    Hi, Coty,
    Good to have another North Carolinian. The Texans currently have everyone outnumbered here but they feel that's the natural order of the universe so we just humor 'em.
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to TFP!
    Joyce
    You're done SLAMing when:
    charlotte
    hello fellow charlottean. new here and just getting a new pool installed.
    36,000 gallon IG
    Tahoe Blue Pebble Tec
    2HP - 60SqFt DE Filtration w/nature2 & in-line chlorinator
    1HP Polaris 380
    1HP Booster w/8ft Waterfall
