Thread: Dichlor question
    Jul 2010
    Oklahoma City
    71
    Dichlor question
    I'm decontaminating my tub now and intend to start the dichlor/chlorine this week. I've got my 6% unscented bleach but not sure what to get for dichlor. I found some small bags of Swimmers Choice granular shock for $4 that contain "Sodium Dichloroisocyanurate dihydrate". Is this the stuff I want to use or is there a better option? Also, since this is a powder, does it measure the same as liquid? In other words, if the pool calculator calls for 1 oz. can I just pour that amount in a measuring cup, just like I would measure a liquid?
    I did get a couple bags so I could super-chlorinate and drain after running the spa flush.
    Thanks in advance for any help,
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Dichlor question
    What you have is dichlor. You can just measure it by the cup, or you can use weight if you prefer.
    Jul 2010
    Oklahoma City
    71
    Thank you sir! I found that measuring the dichlor was tough because the pool calculator called for .4 ounces, I didn't have anything that small so I found a measuring spoon with ML on it, then I had to go online and convert oz to ml to figure it out. Is there an easier way? Or better measuring tools you would recommend?
    Mar 2007
    San Rafael, CA USA
    12,082
    Multiply ounces by 2 to get tablespoons or by 6 to get teaspoons.
    2 tablespoons = 1 ounce
    1 tablespoon = 0.5 ounce
    2 teaspoons = 0.33 ounce
    1 teaspoon = 0.17 ounce
    1/2 teaspoon = 0.08 ounce
    1/4 teaspoon = 0.04 ounce
    If you move your mouse over the field that says "by volume" after it, you will see in the top section things like "1 tsp" for 1 teaspoon, but it's not as accurate as using the numbers above. The Pool Calculator was written originally for pools and though it will work for spas, it's not as precise in its volumes when using measuring spoons that may have 1/2 teaspoon and 1/4 teaspoon units.
    Jul 2010
    Oklahoma City
    71
    Thanks Chem Geek, that is exactly what I needed, I will write this on top of my test kit with a sharpie. I didn't see it on the pool calculator because I was viewing it with this fancy new iPad
