Thread: Freeze Protecton and IC40?
    We are expecting some cold weather this week, so I suspect my pump will be running most of the time.
    I have a Pentair Easytouch & IC40. Do I need to adjust my Cl %, or is the system smart enough to not run the IC40 during freeze protection?
    Thanks
    15,800 Gallon, IG, Pebble Finish. Pentair VS+SVRS Main Pump, WhisperFlo 3 HP Waterfall Pump, IC-40, Quad DE-100 Filter, Easytouch Controls
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: Freeze Protecton and IC40?
    see this
    "...Automatic shut-off feature protects the unit and prolongs cell life under low water temperature conditions..."
    Note: While in “Freeze Protection” mode, IntelliChlor will not operate or produce chlorine during the time that the filter pump is operating.
    http://www.pentairpool.com/pdfs/EasyTouchICPUG.pdf
    http://www.pentairpool.com/pdfs/EasyTouchSystemUG.pdf
    http://www.pentairpool.com/pdfs/easytouch8and4UG.pdf
    If the water temperature is below 60° F, then it's probably best to keep the chlorinator turned off and just add liquid chlorine as needed.
    Support the site
    Thanks, I feel stupid. I must have looked everywhere but there for the answer.
    Actually, I just feel a little more stupid than I normally do.
    I will go ahead and shut it off till spring. Thanks!
