Thread: Can I connect a fountain?
    Wonder if someone can help me.
    I'm relatively new to pool ownership - we have an inground pool that we inherited when we bought the house last year.
    But my daughter has seen a pool fountain online and is asking about it for christmas.(despite living in the UK and pool weather being a long way off!) They look great and at about £25 seem quite cheap BUT I'm not sure they will fit on to our pool.
    Our water inlet/return line does not look the same as the ones I've seen on photos showing how these connect. Even though they all say, multi-attachment, will fit most pools etc. There is certainly no round hole with the water coming in.
    What there is is a flap (excuse my terminology, as I say, I'm totally new to all this), where the water goes in and then the skimmer basket sits directly below that. Under the skimmer basket is a round hole where the water goes down. I fit a vacuum adapter attachment on top of the skimmer basket when I need to hoover.
    The water seems to be coming in through a plate attached to the pool wall directly under the skimmer basket flap. This is a rectangular plate that is about 20cm by 5cm and has lots of little holes in it. I have no idea what this is called, sorry.
    Can I still attach a basic fountain to my pool? Or is it all just a bit complicated?
    Thanks very much!
    May 2011
    Orange County, CA
    696
    Re: Can I connect a fountain?
    I'm VERY confused about what you are trying to describe. Can you provide a link or picture that would have a graphic of the fountain?
    Cheers...
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Hi
    Here is a link to the sort of thing im looking at.
    Sorry I can't provide a pic of my pool. It's all shut for the winter!
    http://www.ukpoolstore.co.uk/acatalog/S ... tains.html
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Hi, welcome to TFP! I have the first two fountains on that link! Those fountains fit on the return inlets. That is where the water returns to the pool after it has been filtered. The opening with the flap you describe is the skimmer. If you use the google search bar at the bottom left of this page and enter "pool return" you should pull up some posts that have pictures of what a return inlet usually looks like.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Joanna, welcome to TFP!!
    From your description, it sounds like you have a 'Pool Genie' (if I got the name right, it's a special skimmer that has the return line plumbed into it). I've never seen one but doubt they would accommodate a fountain
    By any chance do you have a round return inlet in the pool (like, maybe a step return)?
    Pictures of the pool and recirculation equipment might enable us to come up with a workable solution to making your daughter's desire for a fountain a reality
    You came to the correct place to find the best help with pool questions!
    Luv& Luk
    -Ted
