Thread: Astral multiport valve leak
    Greetings,
    Have a slight leak from under the top cover of the valve. At the outer edge of the valve body,
    where the cover fits the body. Which gasket(s) should I be looking to replace? Also, how does the top come off? (i.e. remove handle, remove clip, unscrew or other means). Thanks....
    24 X 52Ěround, Vinyl AGP, 200 lb Sand 1.5 hp filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,588
    Re: Astral multiport valve leak
    You just ned the multiport "spider" gasket underneath. Some of those have a pin/latch to pull out before you can just simply unscrew them. It should be very obvious around the outside edge of it. Handle stays in place, the whole thing unscrews.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Sounds to me like the housing o- ring is bad or the screws are loose.
    Before playing with the valve, please turn off the pump and make sure it won't come on (like from a timer) while you are messing with it! For starters, try tightening the screws that secure the top (do them in pairs E -W, N -S, etc. - keep ~ even pressure on the o-ring, as opposed to starting with one and working clockwise around).
    Do you have the model # of the valve? With that we can look up the correct o- ring for your unit.
    Luv& Luk
    -Ted
    Thanks for the quick reply, I'll see if I can dig up a model # . Most everything on the valve is weathered, but maybe I can find some paperwork......later.....
    all right, forensics complete.....found a sticker with this number on the filter top
    3705N6065A560......If that doesn't help, I'll dig for the manual. Thanks again!
