Results 1 to 9 of 9
Thread: Refilling
    Jun 2011
    Arlington, Texas
    18
    Refilling
    I'm actually not starting up or closing the pool, just doing a drain and refill.
    I bought my house last summer. The last owners didn't take great care of the pool. The hardness is through the roof.
    So I'm going drain and refill now that the season is over.
    Anyone that has had to do a refill have any tips on balancing after the fact?
    I've heard horror stories of spending hundreds of dollars on chemicals after fresh refills.
    13,500 Gal / DE / IG / Gunite
    Re: Refilling
    What are the fill water test results?
    pH
    TA
    Calcium Hardness
    Are there any problems, such as stains or scale?
    Support the site
    Jun 2011
    Arlington, Texas
    18
    Re: Refilling
    ****, cant remember. I'm at work.
    If i remember correctly, the tap water is pretty in balance save the alkalinity.
    I think the alkalinity of the tap was a lot lower than the pool should be.
    30,424
    Re: Refilling
    My assumption is you plan on doing a partial drain and refill. Draining all at once is usually fine in a gunite pool but, if your water table is high, you don't want to do that but rather do a series of partials.
    Posting you test results would be very helpful.
    Jun 2011
    Arlington, Texas
    18
    Re: Refilling
    Tap:
    FC = 0
    PH = 7
    TA = 100
    CH = 90
    CYA = 0
    I plan to replace about 80% if the water so I didn't test the current water. Not to mention I'm out of regents.
    Jun 2011
    Arlington, Texas
    18
    Re: Refilling
    Oh yeah, and I do have scale as a result of the CH being way to high.
    Sep 2011
    Plant City, Florida
    38
    Re: Refilling
    Check your water table around the pool! Doing that in FLA. can result in your pool floating out of the ground like a boat.
    Jun 2011
    Arlington, Texas
    18
    Re: Refilling
    North Texas. The ground is pretty hard here.
    30,424
    Re: Refilling
    80% should be just fine. Being somewhat chicken, I would probably do 70% on one drain and then 20%-30% on a second one. That'll accomplish virtually the same thing with only a little extra water lost.
