Thread: High Chlorine and Ph
    I reside in northern California my pool was recently build today was the last day that the pool company came and check the water numbers. I don't know the test results they got but i recently took them and my pH is 7.8 and my chlorine levels i could not read it because the color was orange (that means really high right ?). My pool system has the IntelliChlor®
    Salt Chlorinator, no salt has been added but i don't think that's the problem. I have no clue what to do.
    Thanks
    Melvin
    16,000 gallon. raised spa 800 gallons
    Filter Sta-rite 450MM
    Circulation pump Sta-rite Vs-3050
    In Ground Plaster
    IntelliChlor®
    Salt Chlorinator
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: High Chlorine and Ph
    Hi, welcome to TFP! Did the builder leave any instructions on caring for the new plaster? The chlorine level will come down on its own. What are you using to test the water? Please post any current test results you may have. Read through the New plaster start up article and let us know where your pool is in this process.
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    One thing to know is that high chlorine will throw off the color of the pH test. So don't trust the pH reading.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Like Richard said, very high chlorine can throw off the pH reading, making the pH results unreliable.
    The oto test only measures up to 5ppm chlorine, all you know is your chlorine is above that. It would be worth your while to invest in a better test kit, like the taylor or TFtest kits with the DPD-FAS chlorine test. With them, you'll be able to get more precise measurements on chlorine levels. Not to mention, you'll be able to test other relevant factors like CH, TA and CYA. Posting those test result will help us (and you) diagnose problems.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    The pool was done 10-22-11. the builder informed us that we had to wait three weeks for the chemicals to balance. that time has past and still the chemicals are high. Im going to run to a pool supply a pick up one of the kits you guys mention and go from there.
    Thank you
    Melvin
    In Ground Plaster
    IntelliChlor®
    Salt Chlorinator
    Mar 2007
    San Rafael, CA USA
    12,082
    It's very unlikely that the pool store will have the Taylor K-2006 kit that you need. You can either get that kit online or can get the TF-100 from TFTestkits.net that uses the Taylor reagents but has a more logical and economical amount of them.
