Thread: 410A In Pool
    Jun 2011
    Jensen Beach, Florida
    22
    410A In Pool
    Installed my heat pump and the exchanger was cracked in shipping. Caused 410A refrigerant to get into pool. Turned it off immediately. After factory swap out I have a sheen of oil on the surface.
    Is there any way to get the sheen out? Not sure if it will evaporate or not.
    10k gal pebble tech, intelliflo vs pump, ic40 swg, dynamic filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: 410A In Pool
    I would try something like a Scum-Ball or Sun Sorb. They are designed to remove oil from the water, and you are probably seeing compressor lubricant.
    Re: 410A In Pool
    R-410A is a gas at room temperature and pressure, so it should not be part of what you are seeing in the pool. In addition to an absorbent material, you might want to use an enzyme based product such as Pool First Aid by Natural Chemistry.
    http://naturalchemistry.com/pool_spa/pr ... t_aid.html
    Support the site
    Jun 2011
    22
    Re: 410A In Pool
    Thank you. I will try both.
