Thread: Using Sodium Bisulfate to remove stains?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    can we use this to remove a stain? Instead of draining a pool and acid washing off one stain, can Sodium Bisulfate granulars be used in the pool water to remove a stain?
    Thanks for any feedback.
    Re: Using Sodium Bisulfate to remove stains?
    What kind of stain?
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    Have you thought of using this tool? It can be used for spot etching or any concentrated chemical dosing be it for Muriatic Acid, ascorbic acid, etc. Of course, getting this tool overseas may be an issue.
    At any rate, I don't see any advantage to using sodium bisulfate over Muriatic Acid, assuming you have some method of concentrating the acid on a particular spot.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Quote Originally Posted by chem geek
    Thanks Chem, I had a Jandy stain remover. Used it once. I might still have it. It was hard at first but I figured it out.
    I guess I will just recommend a drain and acid wash. not worth the time or acid using those stain removers.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Aquatica, before you drain and acid wash the whole pool, you can use a kneehigh stocking to place the bisulfate on the spot ( a rock can be added to keep it in place).
    Too bad you're not looking for someone with my experience to help you out
    Luv& Luk
    -Ted
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Re: Using Sodium Bisulfate to remove stains?
    never seen that tool before. simple but effective. Neat!
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
