Thread: Can Liquidator be converted for PH control?
    Oct 2007
    Central Texas
    104
    Somebody must have tried this already. I have stopped using LQ for chlorine. I was wondering if it could be used to delivery muratic acid.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Re: Can Liquidator be converted for PH control?
    I don't believe it will work. I don't think there is enough of a density difference to keep the acid from mixing into the water quickly. If you need an acid feed system, try this approach.
    Mar 2011
    Hazelton, PA
    57
    Yes you can, but you can't use muriatic. You have to use dry acid. That's how the ph adjuster works, sold by Hasa
    Oct 2007
    Central Texas
    104
    I read that 1 pound of dry acid = 10 ounces of MA, so I won't be doing that. I use 1 gallon of acid per week. So with MA more dense than water, is the issue is that the MA sits at the bottom while the water without MA is taken off the top? I thought MA mixed into water dispersed itself evenly and quickly. Just curious, I am sure that if it worked, HASA would already be selling it. I will take a look at the drip system before going the Stenner pump route. The less things that can break, the better. Thanks for the feedback.
    MA mixes too well. The system does not maintain the division between MA and water well enough and acid is feed into the pool too quickly to be useful.
