Thread: Solar Covers? Is 16x40 really 16x40?
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    I just received the 2 - 16x40 solar covers I ordered and they are not 40' long. They are about 36' 9". I just wondered if that was typical or if they really should have been 40'. I needed a minimum of 38'.
    One 18k gal 6'X75' IG plaster/gunite lap pool w/ 6 sheer decent waterfalls; Delta UV Sanitizer, Pentair Clean & Clear Plus 520; 400k BTU gas heater; Glacier chiller; Pentair Intelliflo VS pump; Robotic Cleaner
    One 16k gal 15’X35’ IG plaster/gunite pool + 7’X7 spa w/ 3 sheer decent waterfalls and 3 pencil jets; Delta UV Sanitizer, Pentair Clean & Clear Plus 420; 400k BTU gas heater; Pentair 2hp pump; Polaris Cleaner
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Solar Covers? Is 16x40 really 16x40?
    My experience has been that they are a little longer than specified. They may have accidentally sent you a 36' cover which is a common size. Contact the seller and let them know. However, you don't really need to cover 100% of the pool so it may still work ok for you if you can get the seller to give you a heavy discount to keep it.
    Mark
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Thanks, I will give them a call on Monday.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I would want a new one. In my experience, having a cover that isn't big enough is a pain, since water always ends up sloshing up on top of it, which makes it less effective. It also looks a bit goofy.
