Results 1 to 10 of 10
Thread: Concrete deck question
    Had pool deck poured 1200 sq ft broom finish. About 80% happy there are some spots that are to rough like the broom was dirty with concrete or something. Anyway its 5 days old and when i sweep or drag foot still getting lot of liitle concrete pebbles fly off and get dust with bromm. Concrete guy says this is normal it will wear down with use, and water. Does this sound normal? sounds like i will be spending first season dealing with concrete pebbles in pool. is this just something that happens with a broom finish due to the ridges?
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    Dec 2009
    Central Massachusetts
    2,690
    Re: Concrete deck question
    Thats pretty typical. It will take some time for that to subside. With a broom finish, you will always have to deal with a little of that, although it wont be bear as bad as in the beginning.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2011
    Montgomery Texas
    89
    How about some pics of the deck.
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    ColdAirGuy's Avatar
    California
    85
    yes do you have any pictures of the pool deck? We are looking to redo ours.....what kinda money did you spend if you don't mind me asking?
    Anthony 16,000 Gallon Oval, White plaster, 30' Long 15' Wide 5 1/2' Deep end 3 1/2' shallow end.
    Pentair Intelliflo, FNS Plus 60sf. DE, Pentair Intellibrite 5G
    TF100 Testkit
    thanks for the reassurance yes i can post pics of progress of renovation . liner goes in today. Well i went with my own concrete guy instead of pool builder he was 5 k cheaper! but it was a bit of a pain getting the two on same page would have been easier to have pool guy do it all. I had 1500 sq ft torn out and 1200 put back in. It was 9k with a light color added and 1k for cantilever. I'm in northeast so things might be more money. Of course pool guy has been negative about everything concrete guy does but thats because i didnt use him to do deck
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    some pics 20x40 concrete wall liner renovation new deck plumbing etc
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    more pics
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    ColdAirGuy's Avatar
    California
    85
    oh wow.....nice and pretty! what a difference! I still need to get quotes on mine.
    TF100 Testkit
    Riles_J's Avatar
    Nashville, TN
    218
    I had a question about the single pour cantilever deck. It seems like the concrete will want to crack at the edge of the bond beam (where coping is typically installed). Just curious how they compensated for that? Did they pour it thicker? Add more reinforcement? Also, it is a bit difficult to see the cantilever in the pics. Did they use those foam forms to do the cantilever (stegmeir rings a bell, as one brand)? How much does it cantilever? Your deck looks great and I am looking at possibly doing a similar style when I redo my concrete this year.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    South Central NJ
    3,192
    There is no bond beam on a liner pool like on a shot concrete pool. The canter lever is only a from the bead track in, towards the water. There is no additional reinforcement needed, just a different liner track.
    There are several manufacturers of forms.
    Scott
    Owner of - PoolGuyNJ LLC
