Thread: Temperature display
    Temperature display
    I have a rome (solarium s-95) heat pump. When it starts it always displays 95 degrees. I set the pool temp I want at 85 degrees and the display goes back to 95. Every thing seems to be working, water heats no error codes turns on and off with the pool pump. It seems the only thing not working is the ability to set the pool temp I want. I think its the control panel, and I going in the right direction?
    e7dave
    Intex Ultra Frame 14 x 42 3500 gals
    Intex SWG combo unit (2000 gph), screen door screening around cartridge:-).
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Temperature display
    Welcome to TFP!
    Sorry I can't help; hopefully someone who can will stop by soon.
