Thread: PVC pressure test Question
    Sep 2007
    Lafayette, Louisiana
    344
    I'm pressure testing the 2" PVC lines tomorrow before I bury them. What psi and for how long do you test? I was going to go to 50 psi for a few hours, but decided I'd see what y'all think. Thanks...
    Jim
    Fortune favors the well prepared
    The build...
    viewtopic.php?t=3974
    Freeform 24' x 38' IG gunite. 3 1/2' to 8' deep. 28,500 gallons. AutoPilot Total Control SWCG. Pentair Intelliflo VF. Pentair CCP520 cartridge filter. Colorlogic LED lights. Tahoe Blue Diamond Brite. 1200 sq ft stamped concrete deck.
    More details as they happen...
    If you are testing the pipe runs, 50 PSI is fine. If you are testing the entire system, you should double check the max PSI rating on your filter and don't exceed that. The filter is generally the part with the lowest PSI rating. Many of them are 50 PSI these days, but a few are lower and several are higher.
    30,421
    Certainly that's adequate. Almost all residential systems are incapable of producing that much. I doubt many pumps can produce more than about 40.
    In a harried, 100 degree workday, I buried my lines without pressure testing them. Happily, there were no issues but that was a really big leap of faith on my part....I would never do that again and am embarrassed that I did it that once.
    Sep 2007
    344
    OK, I figured 50 psi would be fine. It's just the rough in plumbing to the pad, not the equipment itself. I've got about 60-65 psi to the house that I'm pressure up with.
    Jim
    The build...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Man, a pilot shouldn't use up that much good luck at once!
    Jul 2007
    Suwanee, GA
    528
    Quote Originally Posted by JohnT
    And now you'll never hear the end of it.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
