Results 1 to 8 of 8
Thread: Goldline AquaRite No Power LED - Current Limiter Fried
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Just thought I'd share this. The local power company fried the current limiter on an aquarite. see black disc on right...
    New board costs $200+...new current limiter only $3!
    We are replacing the $3 limiter..
    http://www.facebook.com/photo.php?fbid= ... =1&theater
    btw all other displays are working. fuse is good. this is why. but power led off. and you can see a crack on the limiter and also the connections burnt.
    more info on this fix can be found here: http://www.manulabo.com/Hayward/aqrpoweren.htm
    Nov 2011
    Magnolia Texas
    80
    Re: Goldline AquaRite No Power LED - Current Limiter Fried
    I actually have an Aqualogic unit not an Aquarite product but will check this out in the morning. My control unit is also working fine. I may also swap a couple relays around and see if that has any effect too. out. If anyone else has any ideas too I'm all ears. Thanks.
    Steve
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    I have done this repair, as FYI, you're going to need a high powered soldering station or gun to remove the old current limiter. I ordered 2 in case it pops again..
    Grosse Tete LA
    44K Inground liner Goldline Tcell15 SWG
    Jul 2010
    Longwood, FL
    151
    Do you have link which shows how to replace limiter ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    Quote Originally Posted by sunny8088
    This is the topic that you should be looking at: aquarite-not-generating-lights-not-on-t18264.html
    Start at page 12 and work your way back. You will find all the information you need to diagnose and fix the current limiter problem...including a link to you YouTube video.
    Good luck in getting it fixed.
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    I just did this repair on my unit.
    See the write-up and photos here:
    https://www.facebook.com/#!/HaywardAquariteRepair
    My Hayward Aquarite Repair write-up here: https://www.facebook.com/#!/HaywardAquariteRepair
    Nov 2009
    Rock Hill, SC
    1
    THANK YOU for this thread!
    2,000 gallons, vinyl,
    16x24x40 true-L, SWG,
    Sta-rite cartrridge filter, 1 HP
    Polaris 280, 2 SAM LED lights
    itsalive's Avatar
    Feb 2012
    Houston, tx
    8
    Has anyone applied the current limiter replacement solution to a Hayward Pro Logic PL-P-4 motherboard? I have all the same symptoms but the current limiter is yellow and I'm afraid it might not be the same as in the AquaRite systems. Thanks!
    18k gal, 60sq. ft. DE filter, in ground, pebble, 2.5 HP pump, SWG Hayward Aqua Rite T-CELL-15, Barracuda G3 suction cleaning tool
