Thread: Polaris 280 gets stuck at walls and steps
    Dallas, TX
    227
    The front wheel will not turn with enough torque to go up the wall. When it does go, most of the time it takes hard right turns.
    I have changed out most of the bearings, wheels, and tires.
    Any ideas? Or should I just take it to the pool store and let them figure it out.
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    South Central NJ
    3,192
    Re: Polaris 280 gets stuck at walls and steps
    Any hose leaks?
    Scott
    Owner of - PoolGuyNJ LLC
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Did you check the filter in the wall to make sure it's clean?
    Take the case apart and make sure there no leaks at any of the hoses in the water management system.
    Make sure the backup valve is working properly and fully closing after it backs up.
    Just a few ideas based on my experience with my Polaris.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Dallas, TX
    227
    Filter- clean
    Backup valve-good
    Internal hose- good
    Sweeper hose- one small hole I can patch, but that shouldn't affect the wheels, right.
    Only thing I did was take off the float and forgot to put it back on. Now it works fine. Coincidence? What does that thing do?
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    I think the hole in the sweeper hose shouldn't affect much of anything. I was told, however, that the Polaris has a finely tuned water system and any glitch will affect the overall performance.
    Glad to hear it's working good enough again!
    TF-100 test kit.
    South Central NJ
    3,192
    The float keeps it up right. I provides a little buoyancy near the center of gravity.
    Scott
