Results 1 to 7 of 7
Thread: Ecosalt BMSC 20 Gas sensor
    Hi,
    I need help finding a part.
    I have a Ecosalt BMSC 20 Salt Generator. It uses a Gas sensor. The cable has broken from the connector. There is no way to splice it.
    I need to know where can I buy that gas sensor connector, or any connector that I can use by splicing it to the cable coming from the controller.
    Thanks in advace for your Help
    Juan Bossano
    20k Gallon IG Pebble-Tec, 1.5HP Max-E-Pro, Sta-Rite 300 Sq-Ft Cartridge Filter, Polaris 360, 4' Shear Waterfall
    Future - Solar and Automation
    TFT Kit + Pool Calculator + BBB = :)
    Re: Ecosalt BMSC 20 Gas sensor
    Welcome to TFP!
    It is fairly easy to find replacement cells, but I have never seen the gas sensor sold separately.
    Support the site
    South Central NJ
    3,192
    Wow, instead of a flow switch, they use a hydrogen sensor. I don't think I like that. Seems dangerous to wait for enough gas to form before shutting down.
    It seems the manufacturer's site is down with an XML error.
    http://www.monarchpoolsystems.com which is redirected http://www.davey.com.au
    Either the host is messed up or they are out of business. If it's the latter, you're likely going to need a new salt system.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks for all the responses. I will check the links.
    By the Way, If I cannot fix it and decide to use another system, what would you recommend for a 1900 gal swim Spa?
    Price is a strong consideration since I have already spent quite a bit on this spa.
    Juan
    South Central NJ
    3,192
    Are you in Australia?
    Scott
    Hi Scott,
    No, In USA Louisiana
