Thread: Hayward T-Cell and Winter Closing
    Hello,
    First close on our pool. PB did when I was away and Hayward T-Cell is still installed. Shouldn't this be removed and stored in side?
    Here is the install:
    Ted
    South Central NJ
    3,192
    Re: Hayward T-Cell and Winter Closing
    The only manufacturer that I know of that makes this suggestion is Pentair. They also make a dummy cell for this and plaster curing periods.
    Scott
    Owner of - PoolGuyNJ LLC
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    From all the posts I've read in the forum, no need to take it out and I have a Pentair. Never took it out, but I also run the hot tub all winter with the cell unplugged. Since you are winterized, it wouldn't hurt for you to take it off and place it somewhere out of the elements, but you'll need to close up both sides of the pipe also. They suggest cleaning the cell also in the fall, if required.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
