Results 1 to 7 of 7
Thread: Anyone make a DYI stand alone pool cleaner (Filter and Pump)
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    Thinking of making a stand alone pump and cartridge filter to do fall and spring cleaning. Around here we get waaaay tooo many leaves and
    debris. Would like to just plug it in vac the pool and keep all the debris in a seperate system.
    Would put all on a dolly so I could put it in my truck or wheel it around.
    I take care of my pool and the real work at a few friends. The watertech, polaris and other systems I have just do not do it fast nor are powerful enough to suck all the junk out..
    Any ideas or pictures would be appreciated.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Anyone make a DYI stand alone pool cleaner (Filter and P
    This has been discussed before at least once, here is the post I found.
    portable-pool-vacuum-filter-system-t27770.html?hilit=portable%20vacuum
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Try searching for SPP and trolley. SPP is in Indonesia, has a diving pool with a backup filtration system on a trolley.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I see a lot of HammerHead vacuum units hanging off the back of pool service trucks around central Florida. Maybe these guys know something?
    http://hammerheadvac.com/
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by blakeusa
    I've thought about it. Here's my ideas:
    *Use a typical pump, motor, & filter. A cart filter is obviously the lightest (a consideration when moving it around), but a sand filter w/ zeosand/zeolite might be light enough.
    *Wire the pump for 110V with a 50' or 100' cord.
    *Mount it all on a hand truck.
    *When used, send the waste water back into the pool through a Slime Bag (see http://www.cleanerpools.net/).
    *Since the size of the filter, HP of the motor, etc. isn't critical, get all this stuff for free or on the cheap from yard sales, Craig's List, friends who are upgrading, etc.
    I've got a safety cover and dirt & some debris gets in over the winter. I've always thought that a second filter would get the water cleaner quicker at opening time. The slime bag would minimize water lost/cost.
    Good luck! Keep us posted.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I don't filter the water when cleaning out a pool, I just exhaust it to the nearest drain. Naturally you lose water but since my pump is used mostly on pool openings there is usually an excess of water from winter snow/rain.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    If you want to have a filter, don't use a sand filter. If you move a sand filter with sand/zeolites/whatever inside, there is a risk of breaking the internals.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
