Thread: Intex pool filter alteration
    First off awesome forum!!!
    I have read in the forum that the bigger the filter and smaller the pump, the better. I have a small 12 foot round intex pool 1500 gals. It came with a 500 gph pump that I got rid off and now have a 1000 gph intex pump with filter. I also scored a 250 pound Jacuzzi sand filter off a friend. My question is can I remove the filter from the intex pump and hook the pump up to the sand filter? Will the little intex pump have enough umf to work in this set up? Also will it effect the flow rate as I do have an intex salt water clorinator that requires a certain flow rate? Thanks for any help in advance.
    Intex Ultra Frame 14 x 42 3500 gals
    Intex SWG combo unit (2000 gph), screen door screening around cartridge:-).
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Intex pool filter alteration
    bg, welcome to TFP!
    There's no reason that shouldn't work. You may have to do a little bit of MacGyver-ing to get the connections to work correctly, but I know there are a few threads around that show what other people have done.
    Do you think it would change the flow rate going to the SWG, I also got 1.5 HP pump with the filter put I am assuming that is way too powerfully?
    Oct 2009
    3,899
    I don't think it will slow the flow rate at all.
