Results 1 to 12 of 12
Thread: How would you repair this leak? Video
    Hello,
    I have a pretty large pool leak under my concrete. I have read many of the threads on this site about cutting concrete.
    I'm thinking of getting a diamond blade for my circular saw and trying to take a square out of the concrete to get to the broken pipe.
    Please, look at the video and give any advice you can.
    If you can determine what kind of pipe it is, that would be nice, too.
    I tried shutting off the skimmers one by one to see is the leak lessened, but it did not.
    I started at the end of last year, before winterizing. We thought we would deal with it in the Spring. When we opened, it was not leaking. The loud noise if makes was gone, right after we opened. About a month later, it started again. That was really strange. I wondered it debris got into the leak and closed it off for a time. I know this is very odd, seeing as how loud and obvious the leak is, but it really did stop for a time. I hoped it was a miracle, but I guess it wasn't. Even the pool guy that opened the pool could not believe it. He heard it last fall and did not hear it in the Spring.
    Please, watch this video of the leak and give advice.
    http://www.youtube.com/watch?v=-1SQed1z8Ws
    Donna
    Donna
    18X37 Grecian Vinyl Liner, X-Stream Slide, 1 1/2HP Hayward Pump, 3/4HP Polaris Booster, AquaRite SWG, Jandy AE3000 Heat/Cool, Jandy Deck Jets, 4.0 Colorlogic Light, Polaris 280 Cleaner
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: How would you repair this leak? Video
    Donna,
    WOW, thats a big leak. It sounds like it's on the pressure side of the system. Where is the water going? Whats in that corner of the pool? Just some advice on the diamond blade for the circular saw. It will take alot of effort and many blade to cut that concrete and you still won't cut all the way through it. It might be better just to remove that corner piece and it will give you more room to work.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    That corner piece of concrete is a large rectangular piece. The split was the line they put to help with cracking, but the leak has opened this one up. It doesn't look bad, but it is definitely separated all the way through. The water seeps into the ground. It only shows up as a damp spot in the dirt outside the concreted area.
    Donna
    You could rent a 14" Gas Cutoff Saw and a diamond blade. It will cut through 5" of concrete. Cut out small square so that you can investigate. Put up some sort of barrier to prevent concrete chips from getting in the pool.
    http://www.robinsons1874.com/rental/cut_off_saws.html
    http://www.sunbeltrentals.com/equipment ... catid=s511
    Support the site
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    411
    I'm with JamesW on renting a real concrete cut off saw. Home D has them for like 76 a day.
    You are lucky in that it is obvious where the leak is....
    I would cut back at least a foot or so, and do it so when you fix the decking it will look more natural, rather than an odd shaped cut.
    Cut the outline, then cut some smaller squares so you can break out the concrete with a hammer. Sledge that is.. be careful when removing the concrete and dirt around the pipes.
    When you find the crack, dig around and under it, cut the damaged area out with a hack saw or whatever - clean and scuff/sand the ends and use PRIMER and GLUE. Twist and hold each piece for a minute until cured. Use only Schedule 40 Pipe, most likely white pvc.
    Test after you fix it.... a couple of times. Then try to figure out why it broke or cracked in the first place....
    B
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Thank you so much for the responses. I'm thinking about tracing a skimmer cover or a square that equals the size of a few of the same bricks that are around the pool. That way if I just can't get the replacement concrete to look good, i could just work the bricks in or cover it with a skimmer cover. Are there other things that would not look random and out of place to fill a square hole?
    I really appreciate the step by step instructions given above. The concrete around the pool cost quite a bit of extra money and I so hate to tear into it. It seems concrete for pool decks comes at a higher price than other concrete. LOL
    Donna
    That's such a big leak that it should be easy to determine which pipe is leaking. How much water are you losing per day?
    Support the site
    I'm not sure how much water loss because I have to add water when I run the pump. I stopped running it regularly as soon as water temp dropped.
    Donna
    After repairing the leak (crossing fingers with a positive attitude), what concrete mix would you use to pour back in. I'm thinking I will wait and not refill immediately, but I want to know what to buy.
    Donna
    Just a regular Quikrete Concrete Mix (No. 1101) works well. One thing you can do is to cut notches in the surrounding concrete around the hole to create a ledge for the new concrete so that it won't fall in. Alternatively, you could drill some 1/4-inch holes in the sides of the square hole and put some 1/4-inch stainless steel bolts in the holes but sticking out to allow a way to help keep the concrete from moving.
    http://www.quikrete.com/PDFs/ConcreteSelectorGuide.pdf
    http://www.quikrete.com/productlines/ConcreteMixPro.asp
    Support the site
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    That is a rather large leak!
    I would wonder what caused it?
    Also When filling back in the hole, I would fill with something like a fine gravel that wont need any compaction. I am betting you probably have quite the void under your deck from the water running off. Pics of the repair process please!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Thanks again, everyone. I will continue to follow this thread and I do appreciate your time and advice.
    Donna
