Results 1 to 7 of 7
Thread: High chlorine
    High chlorine
    I've begun to trust people here much more than our pool store I have a SWG in our pool 10800 gal. I've had the intellichlor at 0% for over a week but the chlorine is still wayyyy high, is there anyway of lowering it?? The water is clear, 60 degrees (burrrrrrr)
    FC 14
    CC .5
    TC 14.5
    PH 7.5
    CH 600
    CYA 80
    Thanks in advance for any help.
    Jun 2010
    TT
    85
    Re: High chlorine
    One way would be to reduce pump run time.
    Re: High chlorine
    Is the pool covered?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: High chlorine
    I say do nothing. If the water's 60 degrees, no one's getting in anyway. It'll go down eventually with the SWG off. 14 is not all that high for 80 CYA.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: High chlorine
    I agree with Richard, but you can turn the SWG off also.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Re: High chlorine
    Quote Originally Posted by nittany168
    FC 14
    CC .5
    TC 14.5
    PH 7.5
    CH 600
    CYA 80
    Your chlorine is 14 ppm?
    160,000 litres (42,000 U.S. galls) 15 x 7 metres (53 x 23 feet) hybrid. Concrete floor, glass fibre walls. 1.5 HP Tifon pump, 150 kg (330lb) sand filter. Free form shape (not a straight edge in sight) 30 years old.
    Dec 2010
    Central California
    15
    Re: High chlorine
    This is my first winter....water temp is 52* and chlorine consumption is real slow. I'm adding about 40 oz of liquid 10% a week and easily maintaining 5PPM FC
    30'x14' (12.5K Gallon) Viking Carmel - Saphire Blue Crystite Finish
    Jandy Stealth Pump - 2 Speed 1.0 HP
    Jandy Cartridge Filter - 340 sq. ft.
    Fiberstars 6004 Metal Halide Light with 4-Position Color Wheel
    Polaris 280
    Maintained with BBB
