Results 1 to 7 of 7
Thread: using liquid chlorine 12.5% for you laundry ?:)
    Quick question. Not really related to pool, but can't find answer elsewhere.
    Pool is closed for the winter, but I still have 1 gal of 2-3 months old 12.5% Austine pool chlorine that I have no use for.
    Can I use it in my washer by cutting dose in half? According to washer manual using more then 2/3 of a cup will damage the washer over time. Can I safely use 1/3 of cup of this chlorine instead of the regular bleach? (the manual doesn't specify the strength of the regular bleach, so I guess they assume it is 6%)
    Thanks
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    South Central NJ
    3,192
    Re: using liquid chlorine 12.5% for you laundry ?:)
    Go for it.
    Scott
    Owner of - PoolGuyNJ LLC
    22,537
    Yes you can. Using half as much will equal the same concentration in the washer.
    Aug 2007
    near the swamp
    806
    used 10.5% in my washer before, I had some pretty white t-shirts
    Mar 2011
    Sunny Central Florida
    91
    I do. I mix half and half with pool water though.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    I'd try using 1/4 cup or less. A lot of "laundry bleach" is less than 6%. Much less.
    You should dilute it before adding it because that concentration could damage clothes if it directly contacts the fabric.
    Support the site
