Results 1 to 12 of 12
Thread: skimmer suction
    skimmer suction
    Hey all, I'm new to the forum and would like to ask a question. I'm having trouble vacuuming my pool. It's and inground pool with liner. I turn the valve at the pump so it'll pull only from the skimmer. Then put the valve on waste. With the basket in the skimmer I put the top on it, then fill the vacuum hose with water and place one end in the top and the other onto the head. I start it up and it pulls for about 30sec then looses its' prime. The only way I can get any vacuum on it is to slightly open the valve up so I'm pulling from the main drain also. Actually I don't think that's really doing anything. I replaced the filter sand in it about 3yrs ago. Have also replaced the valve on top of the reservoir as it cracked on me. Probably due to old age. The vacuum hose is in good shape. Would you recommend just doing away with the basket and top and instead screw in some sort of adapter into the skimmer bottom to put the other end of the vacuum hose in? Any suggestions would be appreciated as this is becoming a real pain. Also when I replaced the sand I put pvc unions on the lines at the valve so I can break them when I again replace the sand. Could this be it? It seems though that it was doing this before although I can't really remember.
    South Central NJ
    3,192
    Re: skimmer suction
    Most vac hoses have a swivel cuff on one end. It should be on the vac head, not in the skimmer on the vac plate. Double check that as I'd put a bet that that is what is happening.
    Scott
    Owner of - PoolGuyNJ LLC
    Re: skimmer suction
    I've never noticed that before or if I did I didn't think about it. I'll try what you said, probably not today, but I'll get back to you and tell you if it works.
    Re: skimmer suction
    I'm resubmitting my earlier post as I'm not sure I did the right thing. I haven't noticed the swivel end you're probably right. I'll have to try it again and let you know what I found
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: skimmer suction
    I stick the vac hose end directly into the skimmer suction inlet. I know that there are some downsides to that, but that's what I do.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Re: skimmer suction
    I did think about that. The head broke on it and I had to get another one. That may be where my perceived trouble started. Got em mixed up. I'm going to try the hose first and if that fixes it then call me a dumb ole country boy!
    Re: skimmer suction
    This is for PoolGuyNJ. You're right. I might be getting a little senile. I just finished with the pool today and it worked good, but not great. It still doesn't suck like it used to, but I'm one happy guy to get done with it. It'll still pick up leaves and dirt and that's all that matters. If you're ever in my neck of the woods I'll feed you a steak and get you drunk. I owe ya! Thanks
    South Central NJ
    3,192
    Re: skimmer suction
    :goodjob
    Scott
    South Central NJ
    3,192
    Re: skimmer suction
    Where would you be? I like steak and tasty beers!
    Scott
    Re: skimmer suction
    Byram, Ms. come on down.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: skimmer suction
    I can smell his steaks from here . Mighty tasty
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Re: skimmer suction
    You hungry too? We'll all get together and have a party by my clean pool.
