Results 1 to 9 of 9
Thread: Small leak at the filter cartridge lid
    Hi All,
    I have a small leak at the top of the lid (cartridge lid), in between the air relief valve and the pressure gauge. It looks like caused by the weather (too much sun and heat in Florida) . Is there something I can use to seal the leak (is about 2-5 mm) that is safe? or do I need to replace the whole lid?
    Any recommendation as cheap and good place to buy it?
    Thanks!
    22,542
    Re: Small leak at the filter cartridge lid
    Can you post a picture of the leak? That will help us decide if it's a structural issue in repairing it. Also telling us which filter model oyu have would help a lot.
    Well, It looks worst, the actual leak is coming from a small section, I am guessing the best option would be to replace it ?
    [attachment=0:1fa5avj9]photo2.JPG[/attachment:1fa5avj9]
    [attachment=1:1fa5avj9]photo.JPG[/attachment:1fa5avj9]
    Thanks
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I've seen these particular pentair housings develop pinhole leaks a few times. Usually one means a few more to follow. You could try patching but it will probably only delay the inevitable.
    If you do patch it, sand it well first and patch both the inside and outside of the leak. Putting a coat of paint over the whole thing might slow any further deterioration.
    Do you recommend to replace the pressure gauge and the release valve too ?
    22,542
    I never recommend DIY repairs to a pressure vessel. I suggest the best avenue is to replace the filter or at least the top housing.
    Let me rephrase my question.
    When I searched online for the part, I see the lid by itself, (with no pressure gauge nor release valve), Even if I buy those 2 as well, I guess I need to assemble them to the lid. Here is where I found it: http://www.poolplaza.com/C-Filter-Parts ... Clear.html (see parts 1,2, and 3). so If I needed to assemble it I was checking if I could re-use my current ones.. I guess it would be safer just to replace the whole lid (plus the valve/gauge)
    Thanks
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If they work you can reuse them. Don't replace them till the break.
    22,542
    What he said. Yeah, just take them off the old one if they're in good shape.
