Thread: Leak in a stainless steel DE filter
    Oct 2010
    Temecula, CA
    122
    It turns out i have a leak on the bottom of my stainless steel filter, just outside where it sits on the stand but before it turns upward if that makes any sense. It's small but it is leaking. I understand that the filter is under pressure so I'm wondering if it would be unsafe to have a welder seal the area and then continue using the filter.
    If it absolutely must be replaced, what are the recommendations for a pool my size. I think all the information is in my signature. Of course I'll do some research but narrowing it down would be helpful.
    Thanks
    Anne
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Leak in a stainless steel DE filter
    How much do you think it would cost to have someone weld it? Regardless if it got a hole through
    impact or abrasion maybe weld it if it's cheap. If it got thin in that area through corrosion scrap it
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Steel filters tend to develop pinhole leaks because of corrosion, and that corrosion is usually quite extensive before leaks actually appear. Which is a long way of saying that the chances are good that it is in such bad shape that there is no point in trying to patch it.
    Oct 2010
    Temecula, CA
    122
    One last question, I have a 48 sq ft Pentair SMBW 4000 Series filter... has backwash valve etc. My pool stats are 16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide...
    Would a 36 sqft filter (Pentair Series 4000) do the trick for my size pool? Is there a chart on the site that might explain what size filter I would need for my pool?
    I have a Whisperflo WFE-6 1.5 hp pump but I will have to ask DH or look at past posts about piping size, it's either 1 1/2 or 2 inches, I can't remember. Probably makes all the difference anyhow. lol
    Thanks, I'll keep looking.
    Temecula, CA
    With a 1.5 HP pump a 36 sqft filter is marginal at best. I would recommend getting a larger filter than the one you have now, not a smaller one. Larger filters have fewer problems, go longer between backwashing/cleaning, and improve the overall system efficiency.
