Thread: Best way to manage 3 poles and hose on the side of cabana
    I would love to see how other people manage their poles and accessories.
    I'm three seasons in and I've yet to come up with a system that doesn't involve throwing it all behind the cabana and then struggling to get the pole I need while wrestling with the hose that has entangled everything.
    All I have now is that cheap little flimsy pole accessory that came with the cheap pool kit that pool company gives you when you buy your pool,maybe that's all I need, I would like to see what is the best available.
    I did start a thread like this a few years ago, I never did get much response.
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    Re: Best way to manage 3 poles and hose on the side of caban
    Support the site
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    We use hooks similar to those in the photo but made of aluminum. Bought them at HD in the section where they sell ropes and chains and bungees and such. They hold the poles. Then we have another set of hooks, sort of U-shaped and 18" long which holds the hose.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    I keep the hose rolled up inside a suncast box with the large buckets of chemicals. I've never actually used the vacuum since the Polaris keeps the pool clean.
    I keep all the poles attached to the brick wall of the house with little L shaped rubber coated things from the hardware store. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I made some hooks similar to those, and use a decorative hose hanger for the vac hose. I need to get some hooks for hanging the different types of brushes.
    +1 on the Aluminum hose hangers... no rust!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
