Thread: Replace temp cell sensor w/o replacing the entire Turbo cell?
    I have the same problem. The "Cell Temp Sensor" reading has been steadily climbing over the last several days and the salt reading is steadily going down. After about a week, the diagnostic menu of the control panel says my pool is a ridiculously high 180-degrees (F). The actual pool temp is below 80-degrees (F), so it is obvious that something is wrong somewhere in the cell temp sensor circuit. I suspect that the low salt reading is a programming side-effect of the high temp reading.
    I wondering if you solved your problem and what the issue was. I've had motherboard issues with my Hayward Goldline controller in the past, so I would like to know if this is likely to be a motherboard issue, a connector issue, or a Turbo Cell issue.
    I'd also like to know if the cell temp sensor can be replaced without replacing the entire Turbo Cell.
    --Scott
    Windermere, FL
    21,000 gallon inground
    Haywood Sand Filter (new sand 2011)
    Vinyl Liner
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Replace temp cell sensor w/o replacing the entire Turbo
    Bumping this. Anyone have any thoughts?
    Love TFP? Become a
    TFP Supporter!
    May 2009
    Rocket Town, AL
    49
    Curious if anyone has a comment on this?
    18x36 In-ground Vinyl, 24,000 gallons.
    Sand Filter, 1hp Hayward.
    SWG
    Polaris 280
    Jan 2012
    340
    The temperature reading comes from the cell. I'm pretty positive it can't be replaced or it would be a warranty procedure like Pentair has done with the intellichlor temp/flow sensor to prevent them from having to pay for a whole cell.
    Do you have a pool store around with the goldline cell tester? It doesn't always fail the cell if it's just a bad temp sensor, but it can't hurt and it should be free
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    JoshU's Avatar
    New Orleans, LA
    542
    Typically a bad Goldline/Hayward cell gives a "HOT" error message if it's a bad temp sensor.
    Is this installed on an AquaRite, AquaLogic?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
