Results 1 to 10 of 10
Thread: Blow out problem
    Sep 2010
    Noblesville, IN
    104
    Blow out problem
    First time closing. I have an in ground vinyl pool with a Paramount floor cleaning system. Took all the gearing assembly out of the cleaner control, put the lid back on. Hooked up the air compressor to the pump. Blew out skimmer line, put in gizmo, turned off skimmer valve. Air started coming out the small lines near the surface. As each bubbled I put a plug in it. When all lines were plugged, bubbles started coming out the bottom openings where the Paramount cleaning jets are not the main drain. I don't know what to do next...Help please?
    16 x 32 15300 gal. IG Vinyl Jandy pump, Jandy sand filter, Paramount circulation system, Automatic pool cover.
    South Central NJ
    3,192
    Re: Blow out problem
    How many zones in the Paramount mushroom?
    Scott
    Owner of - PoolGuyNJ LLC
    Sep 2010
    Noblesville, IN
    104
    There are three floor popups and three other pipes as well as the center pipe. I guess that means 6 outlets.
    South Central NJ
    3,192
    If the lines are 1.5", get three #8 winter plugs with air valves for the floors. Then close the lid and blow the returns, skimmer and drain from the pump. Then blow out the equipment.
    The floors will be air locked. If you had a sun shelf or steps less than a couple feet down, the pop up(s) should be removed and blown/plugged using a blower. A compressor won't send enough air to clear those lines effectively.
    Scott
    South Central NJ
    3,192
    Forgot to add that if the pipes are 2", you will need Paramount's specially shaped plugs with air valves.
    Scott
    Sep 2010
    Noblesville, IN
    104
    Thanks. Looks like I'm headed to the pool store. My middle is 2".
    South Central NJ
    3,192
    The middle is the feed line. No need there. Its the perimeter ones that get the special plugs.
    Scott
    Sep 2010
    Noblesville, IN
    104
    Okay, got the plugs. Blew out first and second floor popup...no problem. While blowing the third, water shot up from the adjacent pipe. Figuring I was blowing the wrong pipe I switched. Same thing happened. I then plugged the other pipe with a standard rubber plug and blew out the last popup. My question now is what happened and is the other line ok with the standard plug in it?
    South Central NJ
    3,192
    It's fine. It just means two time slots for those jets when the system is running.
    Scott
    Sep 2010
    Noblesville, IN
    104
    Thanks a lot. I can sleep now and quit worrying about the temp.
