Thread: This will slow down the build for sure
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    When a man decided to dig a plot in his New Orleans backyard for a swimming pool, he ended up discovering a historic cemetery that dates back to the 1700s.
    Vincent Marcello lives in the historic French Quarter of the city and unearthed 13 caskets while workers dug up his backyard.
    The caskets were said to be stacked one on top of the other underground, at the property that used to be St. Peter Cemetery before it was closed down.
    Read more: http://www.dailymail.co.uk/news/article ... z1dXz5ESDu
    Dec 2010
    San Diego, CA
    1,137
    Re: This will slow down the build for sure
    He must be on pretty high ground for stacked caskets...isn't the water table the reason they have those mosoleum cemeteries?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Maybe not back in the 1700s...not sure what the elevation of the French Quarter is. Google earth says it's between 0 and 10 feet or so (not including the levee), so I bet those caskets were nice and soggy...
