Results 1 to 18 of 18
Thread: Conduit appears to be burnt / melted all over the place
    dissfigured's Avatar
    Oct 2011
    Denton, TX
    51
    All of the conduit running connecting the pump, cleaner, heater to the unit on the side of the house appears to be burnt for lack of a better word. It is as though it is melted.
    Has anyone seen this before?
    [attachment=0:1fyt84ti]IMG_20111112_155250.jpg[/attachment:1fyt84ti]
    [attachment=1:1fyt84ti]IMG_20111112_155236.jpg[/attachment:1fyt84ti]
    In-ground, SWG, 20,000 Gallons, Attached spa w/ Spillover, Hayward system, Cartridge Filter.
    Dallas TX
    Mar 2011
    Hazelton, PA
    57
    Re: Conduit appears to be burnt / melted all over the place
    My guess, would be rust!
    I would guess that it is caused by intense ultraviolet exposure. Are you somewhere that gets strong sun exposure?
    Here is an example of sun exposure: post248286.html
    Support the site
    Oct 2011
    Denton, TX
    51
    Yes, I live in Texas and my pool equipment is on a south unobstructed corner of the house.
    My PVC pipes are barely starting to do that as well.
    Interesting. I was afraid something was burning inside the conduit
    Dallas TX
    If it were due to overheating from the wires in the conduit, then the damage would be all around the conduit. It looks like the damage is primarily on surfaces that are exposed to the sun.
    Support the site
    Mar 2011
    Hazelton, PA
    57
    If that was sun exposure, it would not discriminate it that fashion. The metal in the flex conduit is rusting.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    How could that be rust with a plastic coating on the outside? That's SUN damage.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Mar 2011
    Hazelton, PA
    57
    Moisture on the inside... I've seen it before!
    Why would the rust only be on one side?
    Support the site
    Mar 2011
    Hazelton, PA
    57
    Why would the sun damage only be between the plastic and the metal???
    The sun damage appears to be on the plastic. I don't even see any metal. That conduit might not even contain any metal.
    I don't think that it's rust. The poster should be able to tell if it's rust, or not, by a close inspection. Perhaps they could scrape off some of the brown and see if it's attracted to a magnet. Or, just try a magnet directly on the conduit.
    The exposure of PVC to the UV component of sunlight results in PVC molecules in the first .001" to .002" of exposed surface becoming permanently converted to a complex structure typified by polyene formations. The result is a brownish discoloration, often termed “UV Discoloration,” “UV Degradation,” or simply “Sunburn.”
    http://www.heritageplastics.com/pdf/Eff ... posure.pdf
    Grey pipe will have brown or black streaks
    http://www.jmeagle.com/pdfs/Technical%2 ... sonPVC.pdf
    http://www.pwpipe.com/literature/tb/tb-d9.pdf
    Support the site
    Oct 2011
    Denton, TX
    51
    I know it is called "liquidtight flexible nonmetallic conduit" so I don't know if there is metal on the inside or if nonmetallic means no metal at all.
    I will get my macro lens and see if I can get a better sample and will also scrape some off and inspect it a little closer.
    Dallas TX
    Non-metallic means no metal at all. It has a rigid PVC spiral core for strength. It should be marked "Outdoor" to specify its suitability to be used outdoors. You can try a magnet to see if it sticks to the conduit to confirm that there is no steel.
    Support the site
    Oct 2011
    Denton, TX
    51
    OK, I am guessing sun damage may be right.
    Here are some photos that show a cross section, and clearly no metal where it has been cut.
    Surface almost appears "bubbly" like it is melted.
    So now, what do I do? Do I need to replace it all, or can I just coat it in something to make it more esthetically pleasing?
    This stuff seems pretty thick so I am assuming it looks bad but at this rate will probably take a lifetime to cause a real problem.
    Thanks for all the help.
    [attachment=0:qqe004h4]IMG_3375.JPG[/attachment:qqe004h4]
    [attachment=2:qqe004h4]IMG_3376.JPG[/attachment:qqe004h4]
    Dallas TX
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    I would take a file to knock down the bumps, then paint it with some gray paint. Just my .02.
    22,542
    Either don't touch it or replace it. It'll last many more years just like it is. You could paint it but I wouldn't worry about it.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Sep 2009
    Greentown, IN
    914
    I would be tempted to just plant something in front of it or build a box in front of it to make it less visable and a bit protected from the sun.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    X-PertPool's Avatar
    Exeter, PA
    1,385
    It's definitely from the sun just spray some 303 Aerospace Protectant or shade it to protect it from more damage.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
