Thread: Just Closed, Cover Ripped
    I just closed my in-ground gunite pool in October. We had a severe snow storm here in CT the other week where trees and limbs fell everywhere. Unfortunately a huge limb came down across my pool. I had it removed, but I think that some of the smaller branches may have ripped holes in the cover. Yesterday it was pretty nice out, so I put my cover pump on top of the cover to get the water off from the snow/rain. I ran it for a very long time and when I checked on it this morning, the cover still had quite a bit of water on it and the water level underneath seems to have dropped lower than the level when I closed. Should I keep the pump going to drain the water cover thus also lowering the water underneath until the cover is water free or just leave it alone? I don't want my cover to collapse from weight, but also don't want to waste water and energy draining my pool even more if I don't need to. Thank you.
    Re: Just Closed, Cover Ripped
    If the cover is leaking you need to stop pumping it out. If the water level goes too low you could have much more serious problems. It would be best to repair or replace the cover now, which will make everything easier in the long run, but that isn't strictly necessary.
    Thank you!
    Jul 2011
    Northern NJ
    92
    I was able to buy patch material and Vinyl solvent from my solid cover manufacturer. Works very well, especially if you patch both sides (top and bottom) of the cover.
    Anthony Pool, 35k gal plaster, DE (1.5hp Ultraflow), Rainbow 320, Dolphin Diagnostic 2001 (Advantage) & Polaris, Retrofitted Anthony mod #20 120v Niche light with Pentair 5G & adapter ring, 70's build / recoped and plastered 1.5 years ago
