Thread: Pentair MasterTemp Proplem
    When I start my spa the heater kicks on just like it suppose to but after running for 5 minutes or so the water temp reading on the heater unit says the temp is 110 degrees and the heater cuts off. The water is not even warm at this point. It tries to start a few more times and it will not light. After that I get a service message on the heater. Any ideas?
    South Central NJ
    3,192
    Re: Pentair MasterTemp Proplem
    Sounds like a bad temp sensor. How old is it?
    Scott
    Owner of - PoolGuyNJ LLC
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The temp sensor is in the heater itself, so if there's insufficient water through the heater then it could be overheating. Is there a bypass for the heater that's open?
    May 2011
    36
    I agree, water boiling in the header
