Thread: Pool About to Get Filled with Dirty Water - What To Do?
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    We are going to have our roof and patio pressure washed this weekend and the runoff is going to end up in the pool. Is there anything else I should do besides raise the chlorine to shock level prior to the event and then just keep it at shock level with the pump running until it clears up?
    Thanks!
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Feb 2008
    Denton, TX
    5,061
    Re: Pool About to Get Filled with Dirty Water - What To Do?
    That should be about it. Let the filter run. Just treat it like the water is dirty because essentially, it is.
    There isn't any way to redirect the runoff away from the pool?
    May 2011
    93
    Thanks. Unfortunately, whatever the gutters don't catch will end up in the pool and that may be a lot.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Here is an idea. Don't know if it would be cost effective though
    http://www.newpig.com/webapp/wcs/stores ... ory=187089
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Could you put a winter cover over the pool and run a sump pump or other submersible pump to remove most of the runoff from the cover?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
