Re: Solar Blankets? Any recommendations on brand/material/m
Yes indeed, the 6' X 75' size will either require a custom order, or some cutting. If I cut it, is there a good way to "attach" the pieces together so that it could be removed with a reel?
I actually need 3 blankets. One 15' X 35' for the "cocktail" pool, a 7' X 7' for the attached spa, and the 6' x 75' for the lap pool. So I was thinking I might just get 2 of the 15' X 35' (if they come in that size) and cut one for the lap pool and use the excess for the spa and other odd shapes like the stair entries. Having the spa blanket in pieces wouldn't be a problem.
Since the lap pool cover will be removed daily, if not twice a day, is it best to have a reel for that size blanket (6x75)? The "cocktail" pool blanket would only be removed occasionally, so I was hoping I wouldn't need a reel for that one, but this is my first pool, so if you veterans tell me otherwise, I'll heed your advice.
Thanks for the help thus far.
