Results 1 to 16 of 16
Thread: Solar Blankets? Any recommendations on brand/material/mil?
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    I'm looking for a solar blanket to help keep my lap pool warm and keep the heating costs down. Any recommendations on brands, material or the mil thickness? I will be swimming almost daily, so I want something that will be easy to remove and replace by myself. (pool size: 6' X 75')
    One 18k gal 6'X75' IG plaster/gunite lap pool w/ 6 sheer decent waterfalls; Delta UV Sanitizer, Pentair Clean & Clear Plus 520; 400k BTU gas heater; Glacier chiller; Pentair Intelliflo VS pump; Robotic Cleaner
    One 16k gal 15’X35’ IG plaster/gunite pool + 7’X7 spa w/ 3 sheer decent waterfalls and 3 pencil jets; Delta UV Sanitizer, Pentair Clean & Clear Plus 420; 400k BTU gas heater; Pentair 2hp pump; Polaris Cleaner
    Feb 2008
    Denton, TX
    5,061
    Re: Solar Blankets? Any recommendations on brand/material/m
    Welcome to TFP! Someone with some solar blanket experience should be along shortly.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I've had the best luck with 12 mil blankets made by Midwest Canvas. I believe In the Swim and Poolcenter.com both handle them. I ordered my last one via Amazon from In the Swim and got it delivered the next day in an area rural enough that Fed Ex and UPS won't accept next-day shipments.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I like the 12 mil clear with bubbles. The clear diamond ones trap to much water when wound on a reel and will void the warranty on most reels.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    6x75 will be a hard size to come by. You'll probably have to order a larger rectangle and cut it into strips.
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Yes indeed, the 6' X 75' size will either require a custom order, or some cutting. If I cut it, is there a good way to "attach" the pieces together so that it could be removed with a reel?
    I actually need 3 blankets. One 15' X 35' for the "cocktail" pool, a 7' X 7' for the attached spa, and the 6' x 75' for the lap pool. So I was thinking I might just get 2 of the 15' X 35' (if they come in that size) and cut one for the lap pool and use the excess for the spa and other odd shapes like the stair entries. Having the spa blanket in pieces wouldn't be a problem.
    Since the lap pool cover will be removed daily, if not twice a day, is it best to have a reel for that size blanket (6x75)? The "cocktail" pool blanket would only be removed occasionally, so I was hoping I wouldn't need a reel for that one, but this is my first pool, so if you veterans tell me otherwise, I'll heed your advice.
    Thanks for the help thus far.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    From what I have seen there are sizes up to 30 x 60 readily available. But 75 ft would be hard to find. You can chose your sizes and figure how to cut the covers you need. But attaching pieces together never seems to work out well.
    I would suggest buying a rectangular blanket, say 16 x 40 and cutting two strips 6 x 40. Then use two reels, one at each end of the pool. That would make covering and uncovering the pool quick and easy. The covers are cheap enough. It's good reels that might be a bit of an investment.
    I bought my last cover from solarcovers.com. They seem to have a good selection decent prices and free shipping.
    chiefwej
    Oct 2009
    3,899
    There really isn't any good way to attach two pieces of cover. A custom one may work well, since the material seems to come in ~6' widths and they just weld the edges together to make larger widths.
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Thanks for the suggestions. So 12 mil clear bubbles (not diamonds). I was contemplating getting 8mil, so it would be lighter and easier to handle, but it sounds like they don't hold up very well, nor do they provide the same level of warming or heat retention. Would that be an accurate assesment?
    Does anyone think I need a reel to remove the 15' X 35' solar blanket if it would only be removed occasionally.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I don't think there is a huge difference in heat retention between the different thickness. I have a 16 mil on my pool, but thats because I just try to buy the one with the longest replacement warranty. The sun will destroy any cover here in a couple years, and I can usually get a couple replacement covers for free during the warranty period.
    chiefwej
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Ah ha.... Good strategy Chief! Do they give you any trouble at all on the replacements? I've heard some people say they've had trouble with warranty coverage. Do you think I need a reel to remove the 15' X 35' solar blanket if it would only be removed occasionally?
    Dec 2009
    Central Massachusetts
    2,690
    I've had 16 mil covers and 10 mils covers and i cant tell any difference. Like Chief said, they only last 2 seasons, so buying an expensive cover is a waste of money, IMO.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Re: Solar Blankets - Will a single reel hold 75'?
    Okay, great info. Next question is will a reel hold the 75' length? This may be another reason to get the 8-10 mil.
    22,539
    At 6' wide a reel should support the 75' length. I would go with the 10mil cover though.
    I would recommend a reel whatever size your cover is. Maybe if it were just a spa cover you may not need one but any size at all and I recommend one.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    SLand's Avatar
    Nov 2011
    Bellaire, TX
    14
    Thxs Dave!
    Hi SLand... I was wondering what solution you eventually chose?
    I am in Austin and am in a similar situation -- pool will be 7' X 75' and I'd like a solar cover with reel.
    Thanks!
