Thread: How does IntelliBrite 5G connect to EasyTouch?
    Aug 2011
    Mechanicsburg, PA
    40
    I am reading manuals but yet to find one how the lights are connected to the Easy touch. I am suspecting lights are connecting to the AUX relays.
    True?
    if I have two lights, do I parallel them or connect to different AUX relays?
    Help would be appreciated. I am taking care of all the electrical connections and that one is so far a mistery to me.
    IG double roman vinyl 40x20. 35000 gal. 9' deep. Diving board.Pentair 400HD gas heater, ItelliFlow Variable Flow pump, 520 cartridge filter, two pentair G5 lights, IC60 SWG cell.
    Photo album: http://slava.no-ip.org/~poolpic/photo
    South Central NJ
    3,192
    Re: How does IntelliBrite 5G connect to EasyTouch?
    Just tell the EZT that the aux is an Intellibrite. If you have two in the pool, I would put them both on the same relay. If you have a spa, I would put it on a separate relay if you have the space.
    Scott
    Owner of - PoolGuyNJ LLC
    Aug 2011
    Mechanicsburg, PA
    40
    Quote Originally Posted by PoolGuyNJ
    Scott
    Great!!! Thank you.
    I will just power them from the same AUX relay. I could not believe pentair did not have a single instruction in EZT or Intellibrite manual.
    Jul 2011
    San Antonio, TX
    44
    when setting them up on the EZT, make sure you go into the lights menu >config and enter the lights there (as well as the 'Intellibrites' in the settings menu).... mine weren't syncing until I did that
    12K Gal IG, Gemstone pebble, Intelliflow VF, Whisperflow, Quad 60 DE, Easy Touch 8, Intellibrites, Platinum Legend.
    May 2011
    No. CA
    111
    Quote Originally Posted by satx66
    same thing with any lights. without doing this all lights on/off don't work...
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
