Thread: Leak Detection Co. in Houston, TX???
    Jul 2007
    Katy, TX
    188
    I have a leak and a pool service co. came out and told me that I needed to have a leak detection co. come out to pin point leak as it is somewhere under my surcrete. Anyone dealt with this before and know of a good reputable co to use in Houston Area? Thanks so much!
    ~Andrea
    24,000 IG with spa and 4 ton waterfall. Equipment: Pentair 520 Clean & Clear, Pentair VS+SVRS Intelliflo, Pentair Whisperflo 2 HP, Polairis Cleaner, Intellibrites, Pentair Rainbow 320 in-line Chlorinator, Pentair Easy touch 8 wireless and spa side remote.
    Feb 2008
    Denton, TX
    5,061
    Re: Leak Detection Co. in Houston, TX???
    Sorry to hear about your leak.
    I would try American leak Detection. They have been around a while. 281-355-0055.
    American Leak Detection found my leak. It is pretty cool to see what they do. They test all the piping, inspect the lights and skimmers, even inspected the plaster to rock coping connection which was where our leaks were. Sneaky little gaps under rocks here and there.
    Jul 2007
    Katy, TX
    188
    Thanks everyone. I did actually call them yesterday and they seemed so very knowledgable. I called another co. as well and they were not. So think I am going with American.
    Anonapersona - did they do the repair on your leaks?
    ~Andrea
    The leak they found was not the sort that they can repair. I think if they find plumbing leaks they can do them.
    They marked each leaking area with blue tape. We got a $20 tube of two-part pool epoxy and used about 1/8 of it to fill the tiny gaps between the plaster and the rock coping. The largest was the size of a pea, most were hairline gaps.
    I figured we were losing about 900 gallons a week. The neighbors said the water and stains had been at the curb at the front of the house since the pool was built 10 years earlier so apparently it had been leaking all that time.
