Thread: Just introducing myself
    Mar 2008
    Lake Forest, CA
    114
    I just joined this forum today and wanted to check in and say hello. I have an IG Gunite/white plaster pool with attached spa which was completed in late November of 2006, so I'm still a fairly new pool owner with one complete annual cycle under my belt now. I maintain my own pool and, even though it can be a bother sometimes, I like doing it. I currently use a Taylor K-2006 test kit, and I'm shopping around right now for an automatic pool vacuum (I'm looking very forward to owning one!). Spring is almost here and we're starting to stare at the pool more and more with anticipation of a new swim season! Looking forward to exchanging comments/information/opinions/etc. with you folks in here.
    Greg
    12000 gal IG pool/spa combo,60 sq ft Jandy DEL filter,2 hp Jandy Stealth pump,Jandy LX400 400K BTU gas heater,Pentair Rainbow 300 off-line feeder (never gets used),Jandy Aqualink RS4 with PDA remote,3 Jandy 12" sheer descent waterfall features, Dolphin Oasis Z5 robotic cleaner
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Greg, welcome to TFP! Sounds like you are off to a great start.
    Please make sure to share some pool pictures when you get a chance.
    Sean
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jul 2007
    Va.
    76
    Good to have you here.
    15x30x54 AGP, Hayward 1hp 2 spd pump, cartridge filter, Royal Entrance steps,Pool Rover Jr
    welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Dec 2007
    Central New York
    504
    Jump right in....the water is fine.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to TFP!
    Joyce
    You're done SLAMing when:
