Results 1 to 9 of 9
Thread: Drain Lines closing
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Drain Lines closing
    I winterized my pool this weekend. No problem with the skimmers or the one return. Wasn't able to get any air out of the main drains with either my air compressor or vacuum. Now, my question. All of my lines are at minimum 28" below ground level and then enter my pool house which has never been below freezing during last winter. Do I have any worries with freeze protection?
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Dec 2010
    560
    Re: Drain Lines closing
    Just for confirmation, the pictures below are all of my lines going into the pool house. The 2nd picture provides a good view of all the pool lines going into the pool house. The ground level is shown in the 1st picture. And for reference, the top of the top treated 2x10 is ground level from the other picture.
    TFT-100 test kit
    South Central NJ
    3,192
    How is it that a compressor couldn't blow the drain?
    Scott
    Owner of - PoolGuyNJ LLC
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by PoolGuyNJ
    Scott
    Along those lines, I blew out my neighbors pool this year with my compressor. His main drain is 8 feet down and I got it to blow at 8 psi.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Dec 2010
    560
    OK, here is what I did. I hooked up a line to the drain in the pump. I closed the filter by putting it on the CLOSED indicator and started the compressor. That would mean it was blowing out all the lines in each direction. Without disconnecting the return line leaving the pump, not sure how to address the main drain alone. But my question, would it really matter given my setup. I think not. The level of my water is 18" below deck so anywhere other than in the pool house, my lines are 28" below ground level for the main drain.
    TFT-100 test kit
    X-PertPool's Avatar
    Exeter, PA
    1,385
    It's possible if the MPV is leaking a bit and the compressor doesn't shoot off a huge volume of air you could be losing air out the backwash.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Dec 2009
    2,690
    I think you'll be fine in MD. At 28", it shouldnt be an issue.
    FWIW, I blow the lines with the multiport on recirculate.
    Dec 2010
    560
    I might try it again just to be sure. Practice makes perfect. I wonder if I ran the compressor long enough? I am a visual guy and wondered right away why I wasn't seeing any bubbles. Didn't look too closely and then figured it just wasn't working. I'll put the multiport on recirculate and give it a whirl in 2 weeks. I don't believe it's a problem, because I've built up completely around my pool house so I don't think there is any way that I'm near a frost line, but I'd much rather be safer. Thanks all.
    TFT-100 test kit
    Jun 2007
    New Jersey
    653
    It's not really a question of how long you run your compressor after you open the valve. I do this every year with a compressor and air is creating waves in the pool seconds after I open the valve. You want the compressor to have filled its tank to full pressure and shut off. You want to blow one line at a time. Let the compressor recover and shut off after each line. I blow return on Recirc. and main drain and skimmers on Closed. To blow the main drain, you need to close skimmer lines (and any other suction lines) with their valves or plug them at the pool if your setup won't do that. I use a painting regulator set at about 12 psi and it is plenty. But you want your reserve tank at 90 psi or whatever the max your compressor puts out so that you have plenty of reserve air. Don't just throttle the compressor down to 12 psi.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
