Thread: Goldline controls aqua pod charging station
    Jul 2014
    Cypress, TX
    32
    When I place the aquapod on the charger, it doesn't always charge the unit. The remote always turns on when I place it in the cradle, so the remote knows the charger is there, but I have to work to get it to show the battery charge indicator. If I don't, the remote shuts down as normal when running on its own battery power.
    I'm assuming I need a new charging station, but thought I'd check here first for any other thoughts. I've verified the connectors are clean and the basics of putting it in the cradle securely, but the problem still persists.
    Thanks in advance,
    Craig
    13,500 Gallon in ground Gunite Pool. Pentair challenger 2 HP pump, Natural Gas Heater, and DE Filter. Polaris 280, TF Test Kit, Borates, Acid, and Bleach to keep things clean.
    Re: Goldline controls aqua pod charging station
    I have had no issues with mine, but have only had for six weeks.
    Jul 2014
    Cypress, TX
    32
    Mine is 4 years old and its been fine until recently.
    JayHoov's Avatar
    Mar 2016
    Bradenton, FL
    3
    My Aquapod is 10 years old, charges but aquapod only works about 15 minutes. I am looking to make a poolside charger but I do not know what the charger AC or DC source actually supplies. It is not advised to have 110 VAC near your pool so a plugged in charger at poolside is a really bad idea. I have seen the youtube procedure for destroying the integrity of the aquapod water tight seal and replacing the internal rechargeable battery (doesn't sound like the solution I am looking for). I though a few D-cell batteries could "charge" the aquapod at pool side to extend the AQUAPOD SPA/pool use time. Anyone else interested in solving this problem? New Aquapods ar $300 and Chargers are running around $50. Comments?
    Bradenton Florida, In Ground Kidney Shape - pebbletech, ~20,000 Gallons. 3ft - 6ft, Separate In Ground SPA - both Chlorine, Two speed pump for SPA - Single speed pump for pool, EXCLUSIVE OR switching on heater - set to heat SPA only (manual valves) - alternatively can heat pool, Pentair MiniMax NT pool heater (Natural Gas)
    Hayward Controls with AquaPod; Pool installed 2005, SPA 2007
    May 2015
    Lake Elsinore ca.
    48
    Have you looked at the transformer power pack? Sometimes the voltage ratings are printed on them or you can take a voltage reading with a meter.
