Thread: Hot Tub pump works but no flow
    Hello,
    I was in my hot tub last night and stepped on half of a plastic ring so I did some investigating inside the tub and noticed that my motors were running but there was no water flow running from one of the motors. I tried the air lock test and that didnt work. Any idea on how to fix it or what happened? I am sure the piece of plastic i found in the water has to do with something breaking off.
    Thanks
    ~6400 gal, 18'X48" Intex metal frame pool
    Intex SWG
    1500 GPH Cartridge filter/pump combo
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Hot Tub pump works but no flow
    Sounds like you'll need to pull the pump assembly and check it out.
