Thread: ascorbic acid vs stains results
    Hi all, recently started to notice that all my plastic plastic parts in our pool and our polaris were taking on a dull yellow/brown discoloration.
    Most notable on the skimmer baskets and baskets in the main pump and water feature pump.
    So I took the water to a lab, not a pool store and found that we had a small amount of copper and iron, and a good amount of manganese.
    Which is not a surprise since our whole house water filter turns brown within a week of a fresh filter install.
    The plastic stained the most are the skimmer baskets and basket in the main pump.
    I took out the pump baskets and dipped one in the ascorbic acid last night. It worked great, within 10 seconds it was pure white again.
    I plan on treating the pool and adding the sequesterant this weekend.
    I have three question I hope someone can help with:
    1. should I put cellulose in the pool to help the cartridge filters catch the chelated metals?
    Or is that just a myth? I am guessing the metals are too small to be caught in the cartridge filter even with the cellulose ?
    2. Would it be wise to start filling the pool from my whole house water filter/softner setup in lieu of the outside non filtered hose spicket ?
    3. Since the ascorbic acid worked on the baskets, is my issue most likely iron or manganese? It is my understanding that if it were copper it would have a different affect on the baskets ?
    Thanks much, this forum is fantastic.
    22,551
    Re: ascorbic acid vs stains results
    1) I don't think the cellulose will help.
    2) I would use it to maintain the level but I probably would have water trucked in from a metal free source for a complete fill.
    3) Since the AA worked so well it's most likely iron.
    Thanks for the reply Bama.
    I am in the process of running the full treatment now.
    Its amazing how quickly it cleaned up the pool.
    South Central NJ
    3,192
    Goyom,
    Check this out:
    http://www.culator.com/
    The packets aren't cheap but...
    Scott
    Owner of - PoolGuyNJ LLC
