Thread: Using up old 12% liquid shock
    Getting ready to close soon. Water is in low 50's so I'm turning off the swg and will use liquid shock for Cl until close. Can I use older gallons of shock purchased in August or should I get new? I read in pool school that older bottles of Cl may be lower in concentration, but is there any other problem with using it up? Also, if I do need to get new Cl how should I dispose safely of the old bottles?
    Thank you
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    Re: Using up old 12% liquid shock
    As long as the liquid chlorine has not gotten excessively hot, or very warm for many days, it should be fine to use. The Sodium hypochlorite disproportionates into chloride and chlorate.
    Support the site
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Nothing wrong with using it. To play it safe, simply test the FC level a half hour or so after dosing just to make sure you're getting what you think you're getting.
    Jun 2011
    Cape Girardeau, Mo
    125
    Nothing wrong at all with using it i never throw it away what i have left from this year will get used next year.
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Use it up. How else will you get rid of the stuff besides pouring it in the pool? If you save it until spring it will probably just be salt water by then.
    The only thing to worry about is that it will have lost some of it's original strength, so you may need to use a little more than you would otherwise have needed. The loss in strength shouldn't be dramatic over six to eight weeks, enough to be able to notice a difference, but still reasonably strong.
