Thread: Creation by AquaLeader vs Quest by Sharkline
    Hi All,
    I need help deciding on the pool of my dreams that I can afford...I almost purchased a Creation by AquaLeader and I like it because they say that I can use a SWC with it. The only drawback is that the top ledge is only 6" wide and I'm afraif it would not be sturdy enough. Quest has a 9" top ledge but on the warrany page it states that it is voided if I use a salt water system. Creation is also more in my price range...but I'm worried about the ledge and also about resin that shrinks during New Jersey winters and thus break...
    Any input is really appreciated...
    Thank you,
    CD
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Creation by AquaLeader vs Quest by Sharkline
    Don't worry about the ledge shrinking, if resin ledges were prone to shrink the width wouldn't matter.
    Lots of people in cold climates have resin pools, the ledge isn't supposed to be used for people getting in/out of the pool so the width isn't critical, although personally I like the wider look.
    Also, if you use the BBB method perhaps you can save money by not buying a salt water system. I started my pool with BBB and with a bit of research and help from people here I can say it's a very easy system to use.
    I personally think both companies make nice looking pools.
    Thank you for suggesting the BBB method - I read a little bit about it and I will give it a try.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    If you go BBB (or any route for that matter) get a good test kit, you really need a good test kit. The ones linked to here are great and the prices are good.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I've picked up an 8 year old AquaLeader that's in great shape. The only breakage in one vertical has a small hole that I suspect came from a lawn mower thrown rock. Nothing structurally wrong and only a little sun fading. The pool was from the north side of KC MO so has been through some rough winters.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
