Thread: Time to pick the the pool bottom!
    Sep 2011
    Montgomery Texas
    89
    We have already payed for wetedge altima. But I'm not sure if the extra price is worth it. It seems the altima is just a longer lasting plaster? What do you experts think. We actually like the feel of the little sample we received.
    I was also reading about borates. Would I wait a while before attempting this. Is there anything I should build into the system to make using borates easier?
    24X38'ish 23,500 gallon Geometric with 10x10 spa(12jets), Pentair IC40 SWG, Pentair intelliflow(pool-spa), pentair whispersflow 2HP(booster spa jets), Two Polaris 1.5 Hp blowers, Pentair Wisperflow XF 3HP(2 6 foot water falls), Pentair clean&clear plus 520, Pentair Master temp 400. Intelli PH acid dispenser, Intellitouch with iPhone and iPad control. Two 45000 BTU fire bowls and one 60000 BTU fire pit.
    Re: Time to pick the the pool bottom!
    Any of the treatments that include quartz in the plaster, like Altima, will significantly increase the potential lifetime of the plaster. As a long term investment it is well worth it. Of course, plaster lifetime also depends on how well you maintain your chemical balance, so remember to keep an eye on that as well.
    There is no equipment required or helpful related to using borates. You add borates about once a season and otherwise don't worry about it. The only limitation is to wait 30 days after the plaster is applied before adding borates.
    Sep 2011
    Montgomery Texas
    89
    Thanks Jason, that is reassuring. I think we will stick with the wet edge, now we need to decide on the color. I think I will try the borates after I figure out the salt system. Thanks again Steve.
