Thread: pump
    CT.
    72
    pump
    Pumps tries to kick in but it wont!. Any ideas?
    16,000 gallon outdoor in-ground 16'x32' Kidney painted concrete pool; Hayward super pump, Hayward pro Grid 3620 DE filter(using Fiber Clear). No Heater. 250 gallon stand alone Jacuzzi hot tub .
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pump
    Bad capacitor. Under the bump on the motor if it has one.
    CT.
    72
    Re: pump
    Quote Originally Posted by JohnT
    OK,couple things that dont look good! The plug that goes into the outlet 110v was burnt! When i opened the sides i also noticed that the black connection to the board was also burnt! First it looks like i will need a new board? second what would cause this. It's plugged into a gfi!
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: pump
    Usually it's the result of a loose connection. Have the pump/motor or circuit board been replaced recently?
    If it's the wire for your pump then there could be an issue with the motor, but it would be more likely to blow a fuse or trip a breaker before arcing at the board.
    Try cleaning off the board with some acetone to see if there's any real damage. Hopefully the it's limited to some charring on the terminal. Be sure to check the back side of the board as well. If the problem goes straight through the board (if a relay burned out, for instance) it will be easier to see from behind.
    CT.
    72
    Re: pump
    Quote Originally Posted by spishex
    Looks like it's just chard at the terminal connection. I have removed the board and going to bring it into have the terminal replaced. I cant seem to get the connection off the board and dont want to mess around with it to much! Will post once job is complete.
