Thread: Should a float be used under a mesh cover ?
    Jun 2011
    Cape Girardeau, Mo
    125
    I am going to use a mesh cover this winter would you still use a float under it for a little extra freeze protection?
    Steve Frakes
    15' X 48'' Intex Metal Frame
    Intex Sand Filter 16'' 2650 GPH
    Taylor K-2006 Test Kit
    BBB and Borated
    Re: Should a float be used under a mesh cover ?
    You don't normally use a float under a mesh cover. The typical routine is to keep it taught enough to stay above water until there is an ice surface to lower it down on, or a noticeable snow load builds up and you have to lower it anyway.
    Jun 2011
    Cape Girardeau, Mo
    125
    Thanks Jason i already had it on with no float and i thought that was the answer just wanted to make sure.
    Steve Frakes
    BBB and Borated
