Results 1 to 8 of 8
Thread: Limp multiport handle
    Aug 2011
    Tacoma, WA
    45
    Sorry, I hate to use the work "limp", but not sure how else to describe it. Replaced the spider gasket last week. When I bolted the multiport valve back on and tightened everything up, I noticed that the handle has some play in it. By play I mean it moves up and down freely, but when it actually contacts the valve it will still push it down and rotate around as it should. Before I replaced the gasket I do not believe it did this.
    As far as I can tell the filter works as it should, but I have barely run it. I just want to see if this is normal before I try and run it for any length of time.
    Thanks.
    18,000 Gallon Plaster IG Kidney w/ 400 Gallon Spa.
    Tagelus Sand Filter w/ Jandy Series One Gas Furnace.
    Emerson 1081 Pump, 1.0 HP 1.65 SF @ 3450 RPM.
    Re: Limp multiport handle
    There should be a spring that puts a little tension on the handle and holds it in place. It sounds like you either lost that spring when you took it apart, or the spring is broken or jammed somehow.
    Aug 2011
    Tacoma, WA
    45
    Does the spring sit outside of the valve, like underneath the bottom side of the handle? Or is it something I need to take the valve off again to replace? Any idea where I can find a diagram?
    Thank you.
    no-mas's Avatar
    Jun 2008
    FL
    405
    mine did this also - while it might be the spring, it wound up being a chewed up o-ring on the handle assembly. I took it to my pool store, and they fixed it for the cost of the o-ring... about $2.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Here is a sample parts diagram (Page 6 of the manual in the link below). If the spring is worn out, then the handle can seem loose. If you left out a washer, such as # 3 or # 6, then the handle can seem loose. You should replace the O-rings and lubricate all rubber O-rings and gaskets with a silicone lube such as Magic Lube II.
    Your multiport should have a model number that you can use to look up the exact parts diagram.
    http://www.pentairpool.com/pdfs/Sta-Rit ... alveOM.pdf
    Support the site
    Aug 2011
    Tacoma, WA
    45
    Thanks everyone. So my question now is wwill the valve still work as it is, or do I need to tear it down and investigate? It seems like the valve closes, just the handle isn't being pushed upward. Or is the valve appearing to close, but not closing fully? I appreciate the help.
    22,548
    If it's not leaking anywhere (waste port, bypassing, etc) and it's sending all the water correctly through the water path, I wouldn't worry about tearing it down again. It could be that the new gasket is not compressed completely yet and may settle over time.
    Aug 2011
    Tacoma, WA
    45
    As far as I can tell it is not leaking. I am not seeing any water go through the glass bubble. Is there any other way to tell?
